Hello, I am trying to build my first pc. My current pc is a pre-assembled HP with an intel i7-7700 cpu and nvidia gtx 1050 2gb gpu and I am planning to build a more powerful pc that will last a few years without becoming obsolete. Below I've listed the components I was thinking to buy.
I'd like some advice on a few things:
First of all, I have a 1080p 60hz monitor and I'm not planning to buy a new one immediately, so I've opted for a rtx 2060 for now and maybe upgrade it in one or two years with the new nvidia 3000 series and a new monitor.
I play mostly offline games, like the witcher or assassin's creed for example, so I don't need 100+ fps, but I like to play at high graphics settings.
The question is: will the rtx 2060 be enough to play the next one or two years games at 1080p 60 fps high settings (also considering the new DLSS 2.0) or I should save money on the cpu and buy an rtx 2070 super?
Also I was wondering wether the 3900x is too overkill for gaming/video editing and some multithreaded programming and if it would be better to just buy a 3700x.
And I have a last doubt: is the 3900x stock cooler sufficient with no overclocking (and the automatic Precision boost overdrive) or will it thermal throttle and reach too high temperatures with the risk of damaging the cpu?
Thanks in advance for the replies.
Budget (including currency): 1300-1400€
Country: Italy
Games, programs or workloads that it will be used for: gaming, video editing and programming
Other details
-CPU: AMD Ryzen 3900x
-GPU: RTX 2060
-RAM: Corsair Vengeance LPX 2x8 GB
-MB: MSI B450 gaming plus max
-PSU: Corsair TX550M
-SSD: Sp Silicon Power M.2 512 GB
-Case: be quiet pure base 600 mid-tower
https://linustechtips.com/topic/1190089-first-pc-build-advice/
3900X is way overkill, I don't think new builders realize just how robust the AMD lineup is.  The 3600 is a 6c/12t solid workhorse that would do everything you need it to.  So yes,  the 3700X is more than enough, whereas the 3900X is just spending too much (even if it's cheaper than the 9900K).
Get the 3700X and get more GPU or storage, I recommend.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1190089-first-pc-build-advice/#findComment-13569001
56 minutes ago, boggy77 said:
Thanks for the replies.
Yes, I also think the 3900x is a bit overkill today, but do you think 3700x will age well? I was planning to save money on the gpu for now since I have a 1080p60Hz monitor and maybe buy nvidia 3000 series along with a new monitor in one/two years, but I'd like a CPU that will serve me well for at least 3/4 years.
https://linustechtips.com/topic/1190089-first-pc-build-advice/#findComment-13569277
3700X is a 4-5 year CPU IMO.   We are in a state of more cores/threads, but the programs/games need to then scale up.  By the time 8c/16t is having issues, it'll be a good 4-5 years I think.
Think about how a 4/8 CPU (7700K) still handles itself very well, and how we have lived on 4/8 for almost a decade now.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1190089-first-pc-build-advice/#findComment-13569507
9 minutes ago, Manjit73 said:
Actually the ryzen 7 3800x doesn't have a price so it might be more costly than you expect
The price is about 40-50€ higher than 3700x if I remember correctly, unless I buy from 3rd party sellers on amazon, but at least for cpu and gpu I prefer to buy directly from amazon just to be safe in case of damaged product or other problems.
But apart from that, I've read over the internet that 3800x (105W TDP) performance is only marginally better than 3700x (65W TDP), so I would probably need to buy a dedicated cooler rather than using the stock one.
https://linustechtips.com/topic/1190089-first-pc-build-advice/#findComment-13569741
