Hello,
My specs:
CPU: Ryzen 5 3600
MOBO: MSI B450 Tomahawk
RAM: G.SKILL Aegis 16GB (2x8GB) 3000MHz CL16
PSU: SilentiumPC Vero M3 600W 80 Plus Bronze
GPU: Gigabyte RTX 2060 super GAMING OC
My problem:
1. A lot of games crashing in random moments
2. Blue screen's popping up randomly while instaling programs, searching thru the web
What i've tested:
Graphic card with different pc (no problems)
HDD with different pc (no problems)
updating bios from version  7C02v1B to version 7C02v1D (after that blue screen's appeared more often)
What i think is the problem:
I think the RAM doesn't want to work with my Ryzen 5 3600
Common blue screens:
https://linustechtips.com/topic/1190043-solved-ram-problems/
Could you have possibly be more vague?
Please provide more information:
What exactly is your problem?
What motherboard are you running?
Was it working before?
Are you running the RAM at its XMP profile?
What is the model number of your ram? It’ll look something like this “CMR32GX4M4C3466C16”
edit: I see you updated your post, ignore this.
Laptop: MacBook Pro 13" (Early 2015) || Motherboard: Gigabyte Aorus x299 Gaming 9 || CPU: Intel i7-7820x (38% OC- 5.00 GHz) || RAM: Corsair Vengeance RGB 8GB @ 3466 MHz (x4)- DDR4  || GPU: MSI  Geforce GTX 1080 Ti Lightning X || Storage: Samsung 960 EVO NVME SSD 500GB || OS: Microsoft Windows 10 Pro || Chassis: Thermaltake The Tower 900 || Cooling Solution: Custom open loop water cooling system with a 560mm radiator and a CPU water water-block || Display: ROG Swift PG279Q || Pointing Device: Razer Mamba (2016) || Keyboard: Razer Blackwidow Chroma V2 || Headset: Astro A50 Wireless ||
https://linustechtips.com/topic/1190043-solved-ram-problems/#findComment-13568678
My problems:
1. games are constantly crashing in tottaly random moments with no errors
2. i get blue screens while searching in the web, or installing programs
My motherboard is: MSI B450 TOMAHAWK with bios version 7C02v1D
i have XMP enebled and ram speed is set to auto
my ram model number is: F4-3000C16D-16GISB
https://linustechtips.com/topic/1190043-solved-ram-problems/#findComment-13568730
3 minutes ago, Krellix said:
My problems:
Did you try running everything on default setting in the BIOS (no over clicking)?
https://linustechtips.com/topic/1190043-solved-ram-problems/#findComment-13568745
i've tried that, clicked restore to defaults in bios settings, but the issues remained
even disabling xmp didnt help ram speed was set to 2133 MHz
https://linustechtips.com/topic/1190043-solved-ram-problems/#findComment-13568792
