aRGB pin definition
Solved by Mamonos,
1 minute ago, Grant Hughes said:I never considered that, I might just bite the bullet and purchase the above listed components, and if I come against any issues then I shall return them.
Thank you very much for your reply.
You are welcome.
Most of the time RGB and ARGB use the same type of header but one of the pin is not used (You can also spot 3 wires instead of 4).
It should work. But unfortunately I've never had those product on hand and I am not able to provide additional information, especially on the degree of control/customization available (which is always the problem with RGB/ARGB products).
