Hi! MSI Sekira Case and going to be using a custom water loop. Mobo is Msi x570 gaming edge wifi.
So, here is the question. I have 5 case fans, and a mobo with 4 sys fan headers, a cpu fan header, and a pump fan header. How would this work?
Can I plug 4 case fans into sys header, the loop into pump header, and last case fan into cpu header? What do I do with fans on the radiator? Is there a way I can get away without using a 4 Pin PWM to Dual PWM splitter?
All are 4 pin pwm, by the way for case.
https://linustechtips.com/topic/1189231-case-fans-with-custom-loop/
I would suggest to plug the pump into the CPU header as that would give it feedback to the system if the pump were to fail. As for the other fans why so you not want to use a fan splitter or PWM fan hub since that would all for grouped/zone control.
