Budget (including currency): 1100 eur
Country: Czech republic
Games, programs or workloads that it will be used for: mostly used for post scriptum and squad, and for designing in solidworks
I have created this list: https://de.pcpartpicker.com/list/pkRCk6
CPU and GPU will be watercooled and it will be built on wall so no case is needed.
As a PSU I have chosen 750w seasonic connect because of the external bar.
In future I would love to buy a 1440p 144hz monitor and be able to play at least at medium graphics settings,will this be sufficient for next 4-8 years ?
Also if anyone has any tips for better components or pc wall building I would love to hear them.
Thanks for your answers
https://linustechtips.com/topic/1189022-pc-build-help/
10 minutes ago, KrysM0ris said:
I have used United states, but most likely I will be buying it from some local shop if I can find all the things here
You don't need to buy on operating system you can just download them off another computer for free them but it in yours.
https://linustechtips.com/topic/1189022-pc-build-help/#findComment-13561388
Yeah my bad,
https://linustechtips.com/topic/1189022-pc-build-help/#findComment-13561399
