Ok I’m new here this is my issue I’m building a pc I have a rog strix z370 e gaming I got the i9 9900 non k and I have a rtx 2060 super, G.skill trident Z ddr4 32gb 3200 MHz and power supply 850w
I press the on bottom it turn on cpu fan turn on I see lights the gpu fan work but then they go
off but There is no display on screen I connect ssd drive I’m waiting to install my ssd drive on the board but I don’t think that’s the issue I really need help.
oh yes I try removing the gpu I try removing the ram using only one I removed the motherboard I put on a table I connect all the cable it turn one but nothing on the screen if you can help me please let me know. Thank you.
https://linustechtips.com/topic/1188660-pc-building/
Hello,
my first guess is that you are on an outdated BIOS.
for the i9-9900 to work with that ASUS Z370 motherboard, you need to update the BIOS to a newer version (at least 1803).
Unfortunately with that motherboard model you will need an 8th gen CPU to perform the BIOS update, since it does not feature BIOS Flashback.
https://linustechtips.com/topic/1188660-pc-building/#findComment-13558819
First thing I can think of is ~ Is your BIOS updated on that motherboard? Z370 boards DO NOT natively support 9th gen Intel chips without a BIOS update. If it's not updated you need to borrow an 8th gen chip to update the BIOS to support 9th gen chips.
"Flying is more than a sport and more than a job; flying is pure passion and desire, which fills a lifetime."
Rig: Ryzen 7 3700X - MSI RTX 2070 Gaming X - 2x8GB HyperX Fury @2133Mhz - ASUS Strix X570-E - Corsair H100i RGB Pro XT -
Samsung 970 EVO 500 GB / 2TB Seagate Barracuda - Seasonic Focus Gold 650W - Corsair 275R
Peripherals: HyperX Alloy Elite RGB - Corsair Dark Core RGB Pro - LG 27GL650F 1080p / 144Hz / 27inch - Logitech Z337
Youtube: @Cetarii - Twitch: @Cetarii - Steam: Cetarii  [I know very creative naming right?]
https://linustechtips.com/topic/1188660-pc-building/#findComment-13558823
17 minutes ago, Mamonos said:
Hello,
Thank you you know what type of 8th gen cpu I can used to update that I would look around my area too
https://linustechtips.com/topic/1188660-pc-building/#findComment-13558855
Thank you both of you are saying the something so I have to barrow a 8 gen chip you know that type I can get meaning what chip
set
https://linustechtips.com/topic/1188660-pc-building/#findComment-13558861
set
Any chip from the 8000 series. Doesn't matter if it's an i7 8700k or an i3 8100.
https://linustechtips.com/topic/1188660-pc-building/#findComment-13558865
8 minutes ago, Isigo85 said:
So really what you are telling is is any chop set that is compatible with this motherboard I can update the bios
Any CPU natively compatible with Z370, particularly 8th gen will be able to update the BIOS. You can probably just buy a 8100 from Amazon, update the BIOS, then return it for your money back.
https://linustechtips.com/topic/1188660-pc-building/#findComment-13558938
