the case: phanteks p300 or fractal desing focus G.
good psu: corsair cx 550/650w or txm 550/650w (if you find the mat stock)
cooler master mwe gold 650w or be quiet system power 11 600w are in stock right now.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1187383-need-a-recommendation/#findComment-13550295
don't you think I would need a fan on ether end ?
https://linustechtips.com/topic/1187383-need-a-recommendation/#findComment-13550325
ARtic has some great deal about thei 120mm value packs, like this: https://pcpartpicker.com/product/t7WBD3/arctic-p12-value-pack-563-cfm-120-mm-fans-acfan00135a
5x 120mm fans.
https://linustechtips.com/topic/1187383-need-a-recommendation/#findComment-13550333
