So i recently got an magnavox mwc24t5 24in. First time messing around with crt tv's I was wondering whats the best resolution / refreshrate For fps gaming i should use that it supports. Been having a hard time figuring out what info i should be looking for in the manuals i can find online.
https://linustechtips.com/topic/1187265-crt-help-pls/
CRT monitors will support and display any resolution, up to their maximum. Choose the one that looks best for you.
Refresh rate can be played with, Windows will let you know if you are out of bounds.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1187265-crt-help-pls/#findComment-13549313
CRTs work in a fundamentally different way than LCDs.  A lot of the controls are the same because LCDs were designed to emulate CRTs but they work in a totally different manner.  There are no actual pixels or masks with CRTs. There’s just a scan line.  They’re analog not digital.
https://linustechtips.com/topic/1187265-crt-help-pls/#findComment-13549345
I'm aware but depending on the resolution you chose to run can you get a high refresh rate?
https://linustechtips.com/topic/1187265-crt-help-pls/#findComment-13549363
Waiting on HDMI to RCA converter to arrive, just trying to get a ball park of what I should be expecting to be the peak refresh rate to be
https://linustechtips.com/topic/1187265-crt-help-pls/#findComment-13549367
24 minutes ago, SkylarThatGuy said:
magnavox mwc24t5
CRT TVs and CRT monitors are very different.
Basically the only signal that that CRT TV is going to understand is NTSC 480i over an RCA/S-vid or VHF coax connection.
CRT monitors (those that have VGA ports) can have the clock portions of the signal changed (within the scanning rate range of the tube) to change resolution and refresh rate.
You're going to be hard limited to 480i60 (not counting overscan, so probably less), I'm pretty certain. If not by the TV, then by the adapter. You also won't be able to play any copy protected content over it.
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
https://linustechtips.com/topic/1187265-crt-help-pls/#findComment-13549391
@AbydosOne and @Bombastinator are correct. I didn't realize this was a CRT TV, I thought it was a computer CRT.
I think you will find resolution and performance not up to what you were expecting.
https://linustechtips.com/topic/1187265-crt-help-pls/#findComment-13549546
Define “high” with CRTs the refresh rate is the scan line.  It’s fixed.  There is interlacing which sort of doubles things.  It’s kind of a hack though.  This is an international forum to make things more fun.  Is the tv ntsc or PAL or something else?
https://linustechtips.com/topic/1187265-crt-help-pls/#findComment-13549616
