5 hours ago, ShrimpBrime said:
Does the system post if you wait a while? 120-180 seconds. Thats 2-3 minutes.
Could be trying to train the memory.
Got any other system specs?
The system doesn't post or anything the monitor in blank for about two minutes and then the computer shuts off by itself. My specs are Intel core i7-9700k, Corsair vengeance lpx 16gb, Asus rog strix geforce rtx 2080 super, Seagate 2b, Samsung 970 Evo plus 500gb ssd, and an evga supernova 650 g3. I also have a corsair icue h100i rgb pro xt
8 minutes ago, Guts and Glory said:
The memory is in the correct slots 2 and 4. I don't know how you clear cmos. This is my first time bulding a PC
Oh cool. Fun and not fun first experince. Fun to build, no fun no post.
Ok Im on mobile. This is the link to the support page. Get the manual and do some reading. The proceedure is there.
https://www.msi.com/Motherboard/support/MPG-Z390-GAMING-PRO-CARBON#down-manual
I've been messing around with things and I found out that if I get rid of the graphics card and leave one memory stick in on the 4th slot it will turn on and everything is fine but if I try with both ram sticks in it won't work same with one ram stick and the graphics card in it won't go into post
11 hours ago, Guts and Glory said:
Update: with the help of you guys and a bit of researching I figured out the problem. The motherboard was faulty; the first two ram slots didn't work and both pcie slots didn't work
Glad you were able to figure out the problem. Best of luck.
