Maybe you're hitting the limit temperature wise where it starts throttling. If you overclock with after burner change the temp higher. I forgot when I redone my overclocks and was wondering why I was getting 200 khash less ande only using 90% power. Sure enough hit the limit set at 75c.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/118491-extremely-low-khs/#findComment-1580495
my gpu core is at 830 and mem is at 1600 and im only hitting about 40c which is not the case was yesterday
https://linustechtips.com/topic/118491-extremely-low-khs/#findComment-1580507
Did you find a solution? If not I would ask if you changed/updated anything,drivers,sdk,windows update,settings,pool?
Also I would advise against using guiminer as it tends to be unstable.
aperently it just needed a pc restart.... But that didn't work before
https://linustechtips.com/topic/118491-extremely-low-khs/#findComment-1584445
