Hello, I just recently upgraded my rig to a GTX 1660 Super and got an Samsung SSD 500gb and a new power supply, but when I play games I notice that my GPU usage rarely goes above 40% In valorant it rarely went above 20% ( Which I realized could be optimization with the game. My CPU Usually hovers around 60-80% but would that be bottle necking the GPU? I just want to know what I can do to get full GPU usage.
Here are my specs
CPU: Intel Core i7 860 @ 2.8 Ghz
GPU: GTX GeForce 1660 Super
Ram: 16gb Ram
Windows 10
I will let you guys know anything else if needed. Please help! Want to be able to stream with decent fps but my GPU is barely being utilzied
https://linustechtips.com/topic/1183911-help-cpu-gpu-not-fully-being-utilized/
A GPU will not be 100% utilized unless it's required of the GPU. If you have vsync or another frame limiter enabled then the GPU will only push 30 or 60 FPS and only work as hard as it needs to. What resolution, framerate, etc are you playing at?
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
vsync is a heavy setting!!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
  • 4 weeks later...
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
