I'm building my first pc and have learned alot about computers in while doing that but I need help on how to no if the sleeper pc case I'm using will fit a radiator and big gpu. The tower is a Gateway 2000, 1997 model. My GPU is gonna be a xfx 5600 thick III, but this ware I need help will my gpu fit becuase I'm going to put my 240mm radiator in the front part of the case but my GPU might be to big and touch the radiators fans. I have put a bunch of holes in the front part of the case for the radiator once I get it, also I painted the case black (first time spray painting).
https://linustechtips.com/topic/1183511-my-first-build/
Could you post pictures of the areas where it allows for fan mounting? Typically with most radiators wherever 120/140mm fans can be mounted so can a rad. If you have an area where you can mount two 120mm vertically or horizontally you can do a 240mm rad.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1183511-my-first-build/#findComment-13522308
