Do I need a 1000 watt power suppy for PC? Or can I have a 850 watt? My specs are listed below:
CPU: Intel Core i7-3970X @ 3.5GHz Hexa Core
GPU: NVIDIA GeForce GTX 780Ti 2-Way SLI @ 875MHz 3GB
MOTHER BOARD: Asus Rampage MOTHER IV Extreme ROG
RAM: Corsair Dominator Platinum 16GB (4x4) 1866MHz
SSD: Corsair Neuron GTX 240GB
HDD: Western Digital Black 3TB
CASE: Corsair Obsidian 750D
OPTICAL DRIVE: Asus BC-12D1ST
SOUND CARD: Asus Xonar Phoebus
NETWORK CARD: Intel E10G42BT @ 10Gbps PCI Express
WATER COOLING: Corsair Hydro H110 280mm (2x 140mm)
AIR COOLING: 2 Corsair SP120 and 5 Corsair AF140
MONITOR: Asus MX239H 23”
MOUSE: Razer Ouroboros
KEYBOARD: Razer Blackwidow Ultimate
SOUND: Sennheiser HD 558
OS: Windows 7 Ultimate 64-bit
https://linustechtips.com/topic/118289-power-supply/
you could even go with 750w you dont NEED 1000w
Specs
https://linustechtips.com/topic/118289-power-supply/#findComment-1577812
I got 2 GTX 780's currently running on a 750 PSU. Most i've seen it pull is 720 watts and I've not overclocked them coz I know it'll prob blow up, if I do  :D
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
https://linustechtips.com/topic/118289-power-supply/#findComment-1577848
hey if you can afford a 1000W 80plus platinum powersupply and not regret it why not xD?
and if you can go to the platinum 1600mhz cl9
for me a 1600mhz to 1866mhz feels like not a big jump
either go 2133 or 1600 just my opinion. but pretty much a better bang for your buck would be the 1600mhz. and the extra cash might go to the 4930k if it's available or something. or the 4960x.
the asus x79 e-ws is awesome too.
anyways something like a corsair ax860i or the seasonic 1000w platinum is something I'd recommend if you ever want to buy a 1000w psu.
Live your life like a dream.
https://linustechtips.com/topic/118289-power-supply/#findComment-1578862
I have a pretty similar build and i'm using a corsair AX860i.
And my rig wont even consume enough power to make the fan turn on.
Unless im benching or in a demanding game.
Heck even in most games the fan wont go above 500RPM or so.
The highest power draw i have seen during benching is around 700W
Granted that's kind of the reason why i went with that PSU in the first place.
Other then the fact that my 550W old PSU couldn't handle my new rig.
But but yea the psu is still over kill but its silent so i don't really mind the extra cost
https://linustechtips.com/topic/118289-power-supply/#findComment-1580301
