Hi,
I'm running:
Ryzen 3600
MSI Mortar MAX
Gigabyte 1660 Super
In Cooler Master Q300L
With 3 CoolerMaster MF120R and the stock case fan.
The problem is that the cooler master fans are REALLY REALLY LOUD. The stock case fan is DC and is really quiet.
I've setup a custom fan curve through BIOS, but it seems to be partially ignored. My curve runs them at 10% PWM until the CPU hits 70C, but they start to get really loud at about 55.
Do you have any idea why the custom fan curve set in BIOS seems to be ignored? Reviews of these fans suggested them as somewhat quiet, but that's not the case.
Thanks!
EDIT: Forgot to mention that they're connected through the same header with a splitter.
CPU: Ryzen 3 3600 | GPU: Gigabite GTX 1660 super | Motherboard: MSI Mortar MAX | RAM: G Skill Trident Z 3200 (2x8GB) | Case: Cooler Master Q300L | Storage: Samsung 970 EVO 250G + Samsung 860 Evo 1TB | PSU: Corsair RM650x | Displays: LG 27'' G-Sync compatible 144hz 1080p | Cooling: NH U12S black | Keyboard: Logitech G512 carbon | Mouse: Logitech g900
https://linustechtips.com/topic/1182698-custom-fan-curve-problems/
