Headphone Recommendation!
By
GrimReapez
in Audio
in Audio
Solved by rice guru,
7 minutes ago, GrimReapez said:Would the 80hms version be alright as well? Or do you think only the 250s are worth it?
The 250 sounds the best. The 80 ohms are Greta if you find a deal on them otherwise I would go for the 250 ohm
errorcode123_dindin1 ·
Posted in General Discussion0 -
Packhunter ·
Posted in Graphics Cards0 -
4
2
VirusDumb ·
Posted in Programming0 -
Jayraj ·
Posted in Power Supplies3 -
Airmack ·
Kyle89 ·
Posted in Troubleshooting2 -
8
5
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
