I just built a computer and have the Lian Li 011 dynamic case with a rog z390e motherboard and nvidia rtx 2070 super. Everything works completely fine except my audio jacks. The top one I can speak but there is a loud buzzing feedback but cannot hear anything out of it. The bottom jack I can hear perfectly but can't speak. Any advice on how to fix this or what I should do? My monitor has an audio jack but can't figure out how to make that work either. I have an Acer Predator z321qu
Any help would be greatly appreciated as I am new to all of this, thanks.
https://linustechtips.com/topic/1180326-audio-jack-issues/
The audiojacks in the case or the motherboard? What wire are you using for the monitor? Only HDMI and DP support audio transfer.
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/1180326-audio-jack-issues/#findComment-13498706
most probably you are confused because these are not combo jacks. Depending on the color you can either add a mic/ or headphones, but if these are combined together using a single cable one of the two devices isn't going to work.
https://linustechtips.com/topic/1180326-audio-jack-issues/#findComment-13498730
