I have decided to build my first gaming PC, and to remain in the budget of around $1000. I have one built on pcpartpicker, and the compatibility seems to check out alright. Does anyone have any idea as to how these parts will function with each other and will they fit into the case I have selected? Any feedback is greatly appreciated.
https://linustechtips.com/topic/1179718-first-build-need-quick-advice/
Go cheaper on the ssd, crucial p1 or p2, maybe wd you can afford an nvme drive for cheaper
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($169.99 @ Amazon)
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard  ($189.99 @ Best Buy)
Memory: *Team T-FORCE VULCAN TUF Gaming Allian 16 GB (2 x 8 GB) DDR4-3200 Memory  ($63.99 @ Newegg)
Storage: Silicon Power A80 512 GB M.2-2280 NVME Solid State Drive  ($68.98 @ Amazon) much better for less.
Video Card: *ASRock Radeon RX 5700 XT 8 GB CHALLENGER D OC Video Card  ($349.99 @ Newegg)
Case: Fractal Design Focus G ATX Mid Tower Case  ($61.97 @ Newegg)
Power Supply: SeaSonic FOCUS 550 W 80+ Gold Certified Semi-modular ATX Power Supply  ($89.99 @ B&H) 750w is overkill for a 5700XT.
Total: $994.90
Generated by PCPartPicker 2020-04-17 22:32 EDT-0400
