Ram memory showing wrong speed
Solved by Mamonos,
Under AI Tweaker in your BIOS
First option is called Ai Overclock Tuner, default should be set to AUTO
Change that to the required D.O.C.P profile (I think D.O.C.P Standard and then below you should see an additional window with the speed of your memory).
VirusDumb ·
Posted in Programming0 -
Jayraj ·
Posted in Power Supplies1 -
Airmack ·
Posted in Graphics Cards0 -
Kyle89 ·
Posted in Troubleshooting2 -
8
5
ken43 ·
Posted in Troubleshooting5 -
9
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
