So I'm planning on getting me a new computer and I haven't finalized what route to go with laptop or desktop. I know that desktops are more powerful and have more flexibility to clean and upgrade but I don't have internet and the only times I get it is when I use my phone's mobile hotspot or I move into my own place in a couple of years. I already have a decent laptop but I was wondering if I should upgrade it or get a desktop. What I do is watch videos, play games, and do some personal work. I don't have the money currently pay for a computer but I'm just getting suggestions for my options on hardware. I'm wanting to run 3 monitors at 1080p or 1440p 120Hz or 144Hz I haven't decided what to go with. I'm wanting some room to upgrade later down the line. I'm planning my budget of no higher than $1500 but is subject to change if necessary. All that I need to be in the budget is monitors and the computer. I already have the peripherals and audio devices and a VGA monitor if i want to hook up a forth monitor to monitor temps and use for Spotify. I can always hook it up to the built-in graphics because I don't need anything powerful to run on that monitor. I don't know what brands to go with but I want something that can stand the test of time. Please leave me with comments and suggestions on what I should do or go with. Thanks.
https://linustechtips.com/topic/1179174-need-help-with-building-a-computer/
new hardware will be on the market in the coming months, as usual. It's best to lay out your performance requirements and budget when you plan on buying.
Primary PC:
PSU tier list
How many watts do I need?
I would expect a delayed launch date.  Q4 is what I would put my money on.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
12 minutes ago, Dawson Wehage said:
MSI B350i Gaming PRO AC
Core i5 6400
Correct me if I'm wrong but this motherboard https://www.msi.com/Motherboard/B350I-PRO-AC/Overview is Ryzen not Intel. Can you send me a link to the motherboard that your are referring to.
Correction its the B150i, that's a typo. Also are you looking for a PC more compact, or bigger?
lttstore.com
6 minutes ago, nerfblaster1234 said:
I've always had a good history with Intel never used AMD. So Intel.
I can't fit within your budget with 3 144hz monitors, they are too expensive. I need a more powerful graphics card if you want to do 3D Surround. With that I can's fit them in.
lttstore.com
PCPartPicker Part List: https://pcpartpicker.com/list/8Bdtsk
CPU: Intel Core i5-9400F 2.9 GHz 6-Core Processor  ($149.97 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 Black Edition 42 CFM CPU Cooler  ($29.99 @ Newegg)
Motherboard: ASRock Z390M-ITX/ac Mini ITX LGA1151 Motherboard  ($132.99 @ Amazon)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  ($79.99 @ Best Buy)
Storage: Western Digital Blue SN550 500 GB M.2-2280 NVME Solid State Drive  ($69.99 @ Newegg)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($50.99 @ Amazon)
Video Card: NVIDIA GeForce RTX 2060 SUPER 8 GB Video Card  ($399.99 @ Best Buy)
Case: NZXT H210 Mini ITX Tower Case  ($78.99 @ B&H)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($74.98 @ Newegg)
Monitor: MSI Optix G24C4 23.6" 1920x1080 144 Hz Monitor  ($179.99 @ Best Buy)
Total: $1607.85
Generated by PCPartPicker 2020-04-16 22:07 EDT-0400
This is as close I can get
lttstore.com
Just a note amd is also good for games and cheaper and it's not hard to familiarize and if u watch some amd vids by LTT someone you prefer you can see that it has good performance even in games this is Ryzen 5 3600X for $225.99 on Amazon and it performs good and it has more cores than the intel version of it and cheaper than it
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
Reminder⚠️
1 minute ago, Dawson Wehage said:
AMD's has 12 Threads, same amount of cores though.
sorry my bad at that part
Reminder⚠️
Total: $1607.85
With this build can I get way with the stock cooler
5 minutes ago, nerfblaster1234 said:
Can I use GSync with those monitors
nvidia GPUs are compatible with freesync now, which those monitors support.
4 minutes ago, nerfblaster1234 said:
What's the difference and is it really that noticeable?
Basically what G-Sync does is prevent screen tearing while gaming. So unless you can get by without it, it's your choice. It can be helpful if you are playing more precise games like CS:GO and Rainbow Six Siege. Though freesync monitors are supported with nvidia too.
lttstore.com
