So I've had a look on the google for an answer, but when I put my WDG 120GB M.2 SSD on my motherboard it doesnt even detect my Kingston SSD unless its in another SATA Port on my Motherboard, can someone tell me why this happens?
If you need anymore details about the setup then let me know :)
https://linustechtips.com/topic/1177228-mobo-help/
Very often, M.2 SATA interface shares lanes/bandwidth with onboard SATA ports, so if you use M.2 SATA drive, you will very likely disable some SATA ports on your motherboard.
Read your motherboard manual for details, which ports get disabled.
M.2 NVMe is not affected by this, as they use PCI Express interface.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/1177228-mobo-help/#findComment-13475399
