dk why but when I reinstall windows my computer dont have any sound
My sound card hardware ID: PCI\VEN_125D&DEV_1988&SUBSYS_00000000&REV_12
(I have to use a sound card bc my onboard sound is dead)
Driver found on driveridentifier: https://drive.google.com/open?id=1egdPm20IfZr-U9Er3k66BkCP4jcAE3Mr
Video about the problem: https://youtu.be/zo4XdO02d7Y
https://linustechtips.com/topic/1177103-sound-problem-no-sound/
What version of Windows are you using? Have you checked the sound card manufacturer's website to see if you are using a compatible driver version?
Are you connecting your headphones or speakers to the sound card on the back of your computer, instead of the motherboard?
https://linustechtips.com/topic/1177103-sound-problem-no-sound/#findComment-13475655
