25 minutes ago, rawlee said:
Will i lose my raid zero if i dont plug the sata cable in the right ports??
a good way to avoid this is to just use a sharpie or something on the cables and their ports to remind you which plug goes where. I'm not sure if the plugs do anything but if you want to play it safe just mark them.
My profile picure is real. That's what I look like in real life. I'm actually a blue and white African Wild Dog.
Ryzen 9 5900X - MSI Ventus 2x OC 3060 Ti - 2x8GB Corsair Vengeance LPX 3200MHz CL16 - ASRock B550 Phantom Gaming ITX/ax
EVGA CLC 280 + 2x140mm NF-A14 - Samsung 850 EVO 500GB + WD Black SN750 1TB - Windows 11/10 - EVGA Supernova G3 1000W
https://linustechtips.com/topic/1175419-case-swap/#findComment-13461693
