12 hours ago, Adozie said:
I have a i5 4570 @ 3.4GHZ and a 1650. Is my CPU holding my GPU back? I am considering upgrading to a ryzen 7, which one should I consider upgrading too?
I dont think upgrading from an core i5 to ryzen 7 would work on the same motherboard, unless you buy a motherboard which supports mounting ryzen CPU's.
If I were in your place Id go for core i5 9400F.
BOLD not ITALIC
https://linustechtips.com/topic/1175267-i-need-help/#findComment-13462840
I5 9400F also use another socket than the I5 4570 so he would still require another motherboard.  He could try to find an I7 4770 if he wants to keep the same motherboard.  It's probably the cheapest and easiest I7 to find for lga 1150
check which of the two is used the most during a gaming session.  The one close to or at 100% utilization is the one holding back.  I have an rx 590 with an I7 4770 and in the games I play it's always the gpu that holds me back.
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
https://linustechtips.com/topic/1175267-i-need-help/#findComment-13464551
