Need Help Finding Pool
Go to solution Solved by DyGr00339,
www.middlecoin.com
www.wafflepool.com
I thought that there was a thread here recently about a pool that mines whatever is the most profitable at the time, then converts it to Bitcoin and sends it to your wallet.
I am not thinking of multipool, cause they don't give you your rewards in Bitcoins.
https://linustechtips.com/topic/117521-need-help-finding-pool/
Lol I would never take you seriously with that kind of profile picture.  :P
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
https://linustechtips.com/topic/117521-need-help-finding-pool/#findComment-1568321
www.middlecoin.com
www.wafflepool.com
have you used middlecoin? if so what are your thoughts or opinions on it? and is there a way to check your balance between payouts?
i7-3770k, Gigabyte UD5H, NZXT Switch 810, OCZ Agility 3 120GB SSD, WD Caviar Blue 1TB, 560 ti Twin Frozr II OC 2GB, Cooler Master V8, Corsair Vengeance 8GB, OCZ Modxstream 700w, Corsair k60 and M65. OH and RED LED LIGHTS   FUCK YA    :)
https://linustechtips.com/topic/117521-need-help-finding-pool/#findComment-1568433
Middlecoin is having some bad days and the owner has been MIA for a few days.  Lots of people are switching till everything works well again.  Middlecoin has been number 1 for a while.
Other options:
wafflepool
clevermining
hashcows
wemineall (beta)
altcoinplex (alpha)
https://linustechtips.com/topic/117521-need-help-finding-pool/#findComment-1572696
read the sticky thread.
https://linustechtips.com/topic/117521-need-help-finding-pool/#findComment-1573767
