Before you check out the build I'm going, Please note that I'm aiming for a BUDGET BUILD and not an expensive build.
The Build:
Proccesor :  AMD Ryzen™ 5 2600
Motherboard : ASUS PRIME A320M-K
Cooler : Cooler Master Hyper H411R
GPU : GTX 1050 TI
HDD : Seagate Barracuda 1TB
Case : Cooler Master Elite 311
Ram : KINGSTON HyperX Fury 8GB DDR4 RAM (Planning to get one first)
SSD : (Thinking about it)
PSU : GX 550W Bronze
Case Fan: 1
Will this build work without any problem don't really want to have any problem in the future
https://linustechtips.com/topic/1175180-need-recommendation/
well number one, the stock cooler that comes with the processor is more than enough
R U L E  # 1   A b o u t   M e:   I   u s u a l l y   g i v e   D U M B   a d v i c e   a n d   y o u   s h o u l d   n o t   l i s t e n   t o  m e.
https://linustechtips.com/topic/1175180-need-recommendation/#findComment-13459729
The Build:
GPU : GTX 1050 TI
Case Fan: 1
why that case? just curious, there are much better ones for the price
https://linustechtips.com/topic/1175180-need-recommendation/#findComment-13459734
Im just using my old case that i've been using for years and the cooler was quite new there are a few things that i'm using back such as the GPU, HDD, PSU and the Cooler
https://linustechtips.com/topic/1175180-need-recommendation/#findComment-13459738
The Build:
GPU : GTX 1050 TI
Case Fan: 1
also go with a radeon rx 570 instead, it is about %30 faster and cheaper
https://linustechtips.com/topic/1175180-need-recommendation/#findComment-13459742
oh ok. do you mean reusing?
https://linustechtips.com/topic/1175180-need-recommendation/#findComment-13459746
2 minutes ago, TheKurtzman said:
yes that's correct and I also would like to ask is there anyway to change to a more budget CPU?
not unless you would like to go Athlon
https://linustechtips.com/topic/1175180-need-recommendation/#findComment-13459754
if you are on that tight of a budget, get a used pre-built
https://linustechtips.com/topic/1175180-need-recommendation/#findComment-13459759
Just now, TheKurtzman said:
Is the Athlon good for gaming? If not I think I would stick with the Ryzen 5 2600
NO NO NO
https://linustechtips.com/topic/1175180-need-recommendation/#findComment-13459760
I would realy go with a used pre-built if I were you and upgrade it or something
https://linustechtips.com/topic/1175180-need-recommendation/#findComment-13459762
Not really tight of a budget just want to save as much as I can since I rarely play Triple A game
even though, I would go with a used pre-built
https://linustechtips.com/topic/1175180-need-recommendation/#findComment-13459767
unless you really want to build it (trust me, I understand) then I would see if you could upgrade your CPU
https://linustechtips.com/topic/1175180-need-recommendation/#findComment-13459773
Why though? also can i get ur recommendation on which board is much more better? The MSI B450M PRO-M2 V2 or the ASUS PRIME A320M-K
Ya, one sec while I check on that
https://linustechtips.com/topic/1175180-need-recommendation/#findComment-13459774
Well if you can spend $10 or so more, get this: https://pcpartpicker.com/product/9C97YJ/msi-b450m-gaming-plus-micro-atx-am4-motherboard-b450m-gaming-plus
https://linustechtips.com/topic/1175180-need-recommendation/#findComment-13459780
2 minutes ago, birdflyer said:
If lets say i pick this GALAX A320M which is a really tight budget motherboard would it be a steal or it would not be reliable after some times.
https://linustechtips.com/topic/1175180-need-recommendation/#findComment-13459786
also a quick note, right now is a really bad time to buy computer components and such, so If you could wait till this whole world wide pandemic passes, things would be a lot  cheaper. But if you can't, buy as soon as you can before things go further up in price
https://linustechtips.com/topic/1175180-need-recommendation/#findComment-13459788
No, the asus one is way better. although be for warned, A  am4 boards will only last around a max of 5 years from any manufacturer (especially GALAX)
https://linustechtips.com/topic/1175180-need-recommendation/#findComment-13459794
B am4 boards will (typically) last around 10 years or so
https://linustechtips.com/topic/1175180-need-recommendation/#findComment-13459796
that motherboard I recommended to you is a B450 board which will last you much longer and is an overall much better board
https://linustechtips.com/topic/1175180-need-recommendation/#findComment-13459801
