Need Help Overclocking Corsair Vengeance Ram to 3000MHz
Solved by Mike Tyson,
Just now, Matt115 said:
What is the original timings the RAM stick sets as default RAM timings ? You will have to loosten those timings 15 cas latency is to low you won't be able to take her to 3000Mhz. Try 17 CL and change the 35 to 41 and let me know.
