Gigabyte RX 5700 XT Center Fan Issue
Gryfer
My RX 5700 XT is causing me tremendous grief. The center fan *only* is spinning up to 100% fan speed seemingly at random and staying there for extended periods of time (15, 20 minutes) and then just as randomly stopping for extended periods of time (2 minutes, 30 minutes, who knows).
I have adjusted every fan setting possible, I have reset it to factory default, I have done everything I can imagine to do to fix the issue. I have tried Gigabyte's software. I have tried editing BIOS fan curves. I've disabled and enabled smart curves, I've tried to do it manually. No matter what I do, I cannot disable it. I cannot slow it down. I can do NOTHING to change its behavior whatsoever. When I am in the Radeon Software settings, the fan reads out as being at 0 RPM, but only the outer fans are actually at 0 RPM whereas the central fan is at 100% speed.
Please help me fix this if possible -- the noise is intolerable.
SPECS:
- Ryzen 5 3600
- MSI B450 Tomahawk Max
- Gigabyte RX 5700 XT Gaming OC
- Corsair Vengeance Pro RGB (2 x 8 GB)
[Full details: https://pcpartpicker.com/b/Wc29TW]
Time for RMA.......
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
