helpme USB disconnecting issue
Solved by StDragon,
So you need to perform some per-mutative testing. Isolate the scope of issue and thereby the variable.
1. Does the problem occur with just the headset, or a specific USB port?
2. If occuring with every USB port, is it only just the headset, or other devices too?
It could be just a bad solder connection to the USB plug at the end of the headset. Try moving the cable back and forth at the neck and see if you can control this connect/disconnect thing.
