I need help
Solved by Pie Mine,
17 minutes ago, TechnicMasters said:Hi. The rx5700xt is cheaper and has about 15% more performance.
It is worth mentioning however that the 2060 has processing units that are good for streaming, as well as some nice comforts the NVIDIA offers (and of course, RTX). The RX can run quite hot as well, so be sure that if you go with that that you do not get a blower style card. Also, no matter what what, something in your system will be bottle necked. Finding what does it the least it what you want.
