3 minutes ago, Zafile said:
My gpu usage in games is very low. I play GTA V Fortnite and Rainbow six siege. GPU usage is almost allways under 50% and cpu usage almost allways 80+
GTX 1650
AMD radeon ryzen 5 3400g
8gb ram
Try going into your BIOS and see if the gpu usage is maxed out at anything. Also if that doesn't work maybe your GPU isn't getting enough energy to output more performance.
https://linustechtips.com/topic/1170353-low-gpu-usage/#findComment-13419592
You are playin on low medium, then cpu gets more load, on higher setting gpu will get more usage.
It might be that your ram is doing that. Do you have a single 8gb stick? if so you need another one. What is your motherboard?
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1170353-low-gpu-usage/#findComment-13419593
You should always have two ram sticks. If you have two then they will use dual bandwith. Dual badwith gets you more fps, less stutter and fps drops. It can bottleneck your other parts
https://linustechtips.com/topic/1170353-low-gpu-usage/#findComment-13419642
Just now, Zafile said:
it says motherboard LENOVO 3709 and then 40700 win 32581490
how many ram slots do you have in that motherboard? go to the spd tab and give us a screen shot. And the spd tab also tells you how many ram slots do you have.
https://linustechtips.com/topic/1170353-low-gpu-usage/#findComment-13419648
s
slot #1 and #2
https://linustechtips.com/topic/1170353-low-gpu-usage/#findComment-13419652
ddr4 single 8gb and also its prebuilt with 2 years warranty so i dont really want to change anything inside it...
no need to change. If you put another 8gb stick in it without scratching anything it will not void warranty. What does the SPD tab tell you about the ram?
Module manuf?
Dram Manuf?
Part number?
Timings table? Frequenzy (the highest one of them)?, cas latency? ras to cas? ras precharge? tRas? tRC? Voltage?
https://linustechtips.com/topic/1170353-low-gpu-usage/#findComment-13419659
1 minute ago, Zafile said:
so i have to do that? but it seems odd. it should just work if it is prebuilt...
You can try. https://www.wikihow.com/Add-RAM If it does not work you can RMA or keep it. It will give you nice fps boost atleast.
https://linustechtips.com/topic/1170353-low-gpu-usage/#findComment-13419675
Check if you have capped the fps to 60 or more. Then your gpu only uses 50% of itself the achieve the 60 or more fps
https://linustechtips.com/topic/1170353-low-gpu-usage/#findComment-13419680
Module manuf?
Dram Manuf?
Part number?
in slot 1 its blank but in slot 2 module manuf samsung dra manuf samsung part number M378A1K43CB2-CTD frequenzy 1333 Mhz cas latency 17 18 19 19 ras to cas 17 18 19 19 ras precharge 17 18 19 19 tras 40 42 43 43 trc 57 60 61 61 voltage all 1.20 v
https://linustechtips.com/topic/1170353-low-gpu-usage/#findComment-13419688
https://linustechtips.com/topic/1170353-low-gpu-usage/#findComment-13419705
2 minutes ago, Zafile said:
i dont understand anything lol
you have 2x ram slots. Only the second one is used. Put that ram in the first one. done.
it will give you nice fps boost
https://linustechtips.com/topic/1170353-low-gpu-usage/#findComment-13419710
