Hey guys,
Been a while since I've posted on the forums. But essentially I upgraded from my 7700K to a 9700K over the summer and it's been performing really well. I've been wanting to over clock it for a while but haven't had the time. Luckily, corona quarantine offered the perfect opportunity. I'm just looking for a mild overclock, only 4.8GHz on all cores, but I have no clue what voltage I should start with. Any recommendations?
Thanks!
Riptide
| CPUi7 9700K @4.8GHz | Motherboard - ASUS ROG Maximus XI Code | Cooler - NZXT Kraken X52 | RAM - Corsair Dominator Platinum 32GB @3600MHz | GPU - EVGA GTX 1080Ti FTW3 Hybrid @2.1GHz | Storage - Samsung 960 Pro 512GB; Samsung 850 Evo 1TB; WD Black 2TB | Power Supply - EVGA G3 1000 Watt (with CableMod Cables) | Case - Phanteks Enthoo Evolv ATX TG (Anthracite Gray) | Case Fans - Too many Corsair ML120 Pro fans :P |
Peripherals
| Keyboard - Corsair K95 RGB Platinum with Cherry MX Brown switches | Mouse - Logitech G Pro + Logitech G900 Chaos Spectrum | Audio - Sennheiser PC37X + GSX 1000 |
https://linustechtips.com/topic/1170127-9700k-voltage-question/
1.3V with medium level of LLC, should be more than enough for even the worst samples
Desktop benching:
https://linustechtips.com/topic/1170127-9700k-voltage-question/#findComment-13417813
