First build cart confirmation
Go to solution Solved by Daniel Z.,
Looks good. You don't need the CPU cooler though, the stock is good enough
Hello
I am here becouse I am soon going to build my first pc and I want to know if the parts are compadable or if there is a better solution for some parts.
   The PC is going to be used for gaming, streaming and light-weight video editing. I have also chosen some extra quiet fans as I'd like to have the quietest pc possable as right now I have an f18 taking off from my desk all the time and it is SUPER annoying, you can't even imagine it.
   The parts that I have picked out are following: R5 3600 (189.90€), MSI B450 tomahawk MAX (107.68€) arctic freezer 34 esports (29.83€), Corsair Carbide 275R (86.72€), 3x Be quiet silent wings 3 120mm (20.63€ piece), Corsair TX650M (650w for expansion room) (99.52€), Corsair 16gb 3600MHz. So that all combined is 683.65€ and I do have ny storage (1 tb harddrive and 128gb ssd) and the graphics card I'm gonna use (from old system) is the MSI 480 8gb gaming X.
   I hope that its all the info needed and thanks ahead. And again, the purpuse of this build is: gaming, streaming, video editing.
Thanks ahead, RuJuRa
https://linustechtips.com/topic/1169202-first-build-cart-confirmation/
On 3/27/2020 at 1:31 PM, ErA.l said:
How sure are you about that carbide 275? If you are going to spend an extra 60 euros on fans, maybe rather look at a nicer/quieter case that comes with some good fans included?
(Sorry for the late response) Why I want the extra fans is so the pc would be AMAZINGLY quiet and I don't know any case that is stock, that quiet. Do you know any?
