Hello all
I am very new to networking but I am willing to learn about stuff and look things up. But I couldn't find the solution to this problem.
Goal:
I want to monitor my PCs network usage. But I want to do it with a program on another computer, with the "PTRG Network Monitor". (My PC runs Windows 10 Pro and the monitoring PC uses Windows Server 2016 Datacenter)
What I did/know so far:
After a bit of looking around and reading the manual. I see I need to add a "device" so I can link my PC to the software (not sure how relevant this is). I added a "sensor" that pings my PC to see if it is online and a HTTP one. They both work.
But than I wanted to get a networking sensor (and later other sensors like CPU-usage). I did not know how this would work so I just tried it. It said it needed SNMP-acces. After reading some things about it and flowing a few tutorials. I added the feature (it is not stranded on WIndows 10). I checked it and it is listed in the features list.
But I read i multiple sites I need to turn the feature on (using Control Panel > Programs and then clicking on Turn Windows features on or off). But I can't find it in there.
When I go to services, I can see it and is says it is running. I set it up so it gives all types of data and added the IP of the computer with the monitoring software.
But is doesn't work.
Any ideas?
Thanks in advance!
Greeting 42thgamer
https://linustechtips.com/topic/1168663-snmp-setup-problem/
