Hi all,
Some time ago I noticed that every game i played was really laggy because of the fps. Where i'd run league with over 100 fps it now has like max 45 (on the lowest settings). Games like Minecraft dont run on higher fps then 35 (on the lowest settings) and I have no idea how this happend. I have an MSI leopard 8RD with a Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz and a NVIDIA GeForce GTX 1050 Ti. I've already send it in for repair but they send it back and it was still as bad. I hope someone can help.
Greetings.
https://linustechtips.com/topic/1168207-having-some-big-fps-issues-pls-help/
6 minutes ago, Boelian said:
Hi all,
Greetings.
Check if it isn't running on your integrated graphics. That happens often without you knowing.
1 minute ago, Boelian said:
around 40-50°
Im not that great with drivers and all that u have a guide how i do this?
https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Is the software. It says what to do on the page.
But basically select your gpu brand (in your case nvidia). Do the clean and restart (the highly recommended option).
As mentioned on the site do first download the newest driver for your gpu and then disconnect from the internet whilst doing this.
I'll do that, i'll let u know if it helped yes or no
it worked! thank you so much :)
