I have tried plugging in displayport to display port from monitor to gpu & hdmi to hdmi from monitor to gpu, and with both as well. It always results in 'dp no signal' after i turn on monitor. I have tried numerous times unplugging and replugging in cords, in different combinations as well. All my case lights & fans, gpu fans work properly when I turn on power supply. I have tried using 1 ram stick. These are all brand new parts, first time builder.
My computer specs:
CPU: AMD Ryzen 7 2700X
Motherboard: MSI B450 Tomahawk Max ATX AM4
Memory: Kingston HyperX Fury 16GB (2x8)
GPU: GIgabyte GeForce RTX 2060 6 GB OC
PSU: Corsair 650 W 80+ Gold Fully Modular ATX
Case: NZXT H510 Elite
Monitor: MSI optix MAG241C
https://linustechtips.com/topic/1168142-gpu-problem-dp-no-signal/
You have connected GPU to 8pin PCI-E power right? And you are connecting monitor to the video output ports on the GPU and not the motherboard.
Also you only need to use either DisplayPort or a HDMI cable. Not both at same time. You then set your monitor input source to the type of connection you're using.
Yeah, GPU is connected with 8pin PCI-E. I have tried both connecting monitor to GPU then the motherboard, separately.
I have tried using either and both DP or HDMI. I dont think i can set monitor input because there is only a on/off button on the monitor.
There is red a button/joystick on back of monitor for OSD
See Page 2-3 of manual for selecting input
https://download.msi.com/archive/mnu_exe/monitor/MAG241C_CP_CR_CV_271C_CP_CR_CVv1.0_English.pdf
