I’ve got a Asus P8H61-I R2.0 motherboard with Patriot Viper 3 16 GB memory.  I’m new to OCing and learning what I can.  I’ve tried OCing and no matter what I do I can’t go past 1600 Mhz without the computer not posting after reset. Any helpful tips would be appreciated and any other info needed lemme know.
https://linustechtips.com/topic/1167384-memory-oc-help/
I've never done it outside of xmp profile but from what I get from the video you probably need to add a little bit more voltage and loosen the timing first.  Follow the tutorial, it's kinda good.
There you go
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
https://linustechtips.com/topic/1167384-memory-oc-help/#findComment-13394503
