I have two graphics cards in my system, the more powerful one I use to run the games, however I occasionally want to record as well. Is it possible I can use the second graphics card to do the encoding for recording?
i7-8750H, 6 cores, 12 threads
24GB 2667Mhz
256GB SSD + 1TB HDD
GTX 1070 8GB
https://linustechtips.com/topic/1167287-hardware-encoder-for-recording/
No. Don't do that.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
What software are you using?
The whole point of Nvidia's encoder is that it runs on the same card/GPU from teh same memory, so no need to transfer stuff between hardware units. Also the encoder is a dedicated block that wouldn't be used while gaming anyway, meaning you don't lose anything by recording. You're not stressing the same hardware more, you're just using an extra bit of circuitry that's there precisely for the purpose.
F@H
GPD Win 2
OBS. And my GPU is at 100% usage while playing and when I hit record then OBS says the encoder is being overloaded and I drop about 20 FPS in game as well.
24GB 2667Mhz
256GB SSD + 1TB HDD
GTX 1070 8GB
Tried ShadowPlay yet?
F@H
GPD Win 2
Could try the cpu if you are just recording. Depends on how cpu bound the games are.
