MY FIRST PC BUILD ! Please help !!
MOTHER BOARD -----> AsROCK B450 Steel Legend
CPU -----------------------> Ryzen 7 3700X
Cooler ---------------------> ID-COOLING SE-207 CPU Air Cooler https://shopee.com.my/-ID-COOLING-SE-207-CPU-Air-Cooler--i.59277182.1164234827
RAM---------------> CORSAIR VENGEANCE LPX Black [32GB / 16GB] DDR4 DRAM 3200MHz C16 - AMD Ryzen Tuned DDR4 Memory Kit
GPU---------------> ZOTAC GAMING GeForce RTX 2060 SUPER MINI 8GB GDDR6
SSD---------------> SAMSUNG EVO 860 250GB/500GB/1TB M.2 SATA SSD
Power Supply--->Corsair TX-M Series™ 80 Plus® Gold Certified PSU TX750M/TX850M
Budget $1400
https://linustechtips.com/topic/1167039-my-first-pc-build-amd-system/
the MSI B450 Gaming or MAX boards with VRM heatsinks should have a better VRM
what's the price comparison to a 5700? Or just get a dual fan GPU that will cool better in general.
 MAX boards ?
On 3/21/2020 at 4:21 PM, NZgamer said:
Is that 1400 USD? Why don't you use your local currency? Nobody has a problem with that, plus, US pricing will be different to your local pricing.
Anyway, looking like a good build but I'd recommend a better graphics card.
Dollar just guide pricing.  Actual pricing is different like $100-150
Any suggestions form GPU ?
Im just more to editing and gaming .
No Overclocking
  • 2 weeks later...
On 3/22/2020 at 5:08 PM, Mac_nfs87 said:
 MAX boards ?
MAX is just their newest revision of boards, with bios ready for ryzen 3000
On 3/21/2020 at 9:28 AM, Konrad_K said:
Looks decent but i'd stay away from the Mini card, especially if it's not a sff system. A dual-fan 2060 would have significantly better cooling. Also you really don't need a TX850M - such a high wattage PSU isn't really necessary for your build.
The Zotac is dual fan, and is perfectly fine.
