Need Help Picking AIO's
Go to solution Solved by antoainb,
So here is the scoop.
I'm planning my build and I want it to be water cooled without making a full costume loop. So naturally I choose to go with AIO coolers.
Now I have to cool two components. One is the CPU obviously, and the other is a GPU, specifically the R9 290 with the NZXT Kraken G10 bracket.
Now let's get to why I made this post.
I need you guys to find me two coolers that follow the following specifications.
Cooler 1:
  1. Under $150 USD
  2. Fits Intel LGA1150 Socket
  3. Looks cool ;)
  4. Quiet
  5. Dual 120mm rad? Don't know if that's the right way to put it....
Cooler 2:
  1. Under $100 USD
  2. Fits Kraken G10 GPU Mounting Bracket
  3. Cools cool ;)
  4. Quiet
  5. Single 120mm rad
Umm yea think that's it! If you need any more info please let me know and I'll make the changes!
Cooler 1: Corsair H100i
Cooler 2: NZXT Kraken X40, just for the sake of keeping it all with the same brand.
P.S.: Don't forget to replace the fans with Noctuas. ;)
Cooler 1:
  1. Under $150 USD
  3. Looks cool ;)
  4. Quiet
Cooler 2:
  1. Under $100 USD
  3. Cools cool ;)
  4. Quiet
  5. Single 120mm rad
The year is 20XX. Everyone plays Fox at TAS levels of perfection. Because of this, the winner of a match depends solely on port priority. The RPS metagame has evolved to ridiculous levels due to it being the only remaining factor to decide matches.
Only Abate, Axe, and Wobbles can save us.
https://linustechtips.com/topic/116591-need-help-picking-aios/
Cooler 1:
  1. Under $150 USD
  3. Looks cool ;)
  4. Quiet
Cooler 2:
  1. Under $100 USD
  3. Cools cool ;)
  4. Quiet
  5. Single 120mm rad
i'm a potato
https://linustechtips.com/topic/116591-need-help-picking-aios/#findComment-1557226
Yup! Have three Noctuas in my pcpartpicker list just for that! :D
https://linustechtips.com/topic/116591-need-help-picking-aios/#findComment-1557246
Cooler 1:
  1. Under $150 USD
  3. Looks cool ;)
  4. Quiet
Cooler 2:
  1. Under $100 USD
  3. Cools cool ;)
  4. Quiet
  5. Single 120mm rad
kinda would be nice to hear about your rig and the case to fit all this into?
this way the best options are suggested and possibly steer you to a better result.
https://linustechtips.com/topic/116591-need-help-picking-aios/#findComment-1557350
Yea I thought the case was irrelevant because I knew it would fit what I was asking for. It's the NZXT H440 btw and also how do you do the show tab thing???????? I've been trying to do that for weeks!!!!!!
https://linustechtips.com/topic/116591-need-help-picking-aios/#findComment-1557358
  • 3 weeks later...
If your going for 120mm on the g10 a kraken x40 is 140mm not 120mm, if your looking for 120mm i would go for corsair h55.
Main: AMD Athlon X4 750K| Coolermaster Hyper TX3 EVO | Gigabyte GA-F2A75M-HD2 | 8GB Kingston 1333mhz | WD Caviar Green 1tb | Coolermaster N200 | OCZ coreXstream 500w | Sapphire Radeon HD 7850 2GB | |Kingston 3k ssd 128gb |
https://linustechtips.com/topic/116591-need-help-picking-aios/#findComment-1665675
