second monitor HDMI Male To VGA Female adapter stopped working
Solved by johnny5c,
30 minutes ago, Waffle_Loard said:The adapter is being used on a laptop, i tested it successfully on another laptop but am unable to get it to work on mine.
I ran into this with a similar adapter, it uses the +5v in the HDMI output to power the adapter and some devices don't supply enough current for it to function. What it sounds like in your case is the port on your laptop isn't active or active long enough for it to power up and detect a signal. The way I can trick mine into working with some devices is to connect a HDMI monitor and power down the system, then swap the HDMI cable for the adapter and power it back up. If that doesn't work try a adapter that has a external power source.
