The TXM is better than the CXM.
The RM550x is the same price as the TX650M so if you don't need 650W then the RMx would be the better choice. And it comes with a further $20 mail in rebate.
https://linustechtips.com/topic/1165544-power-supply-choice/#findComment-13378594
Or Seasonic Focus GX without rebate for 90$.
Tag or quote me so i see your reply
https://linustechtips.com/topic/1165544-power-supply-choice/#findComment-13378868
