1 hour ago, MrHotPotat said:
hello for the third time. just a bit curious. is it nessensary to keep your hard drive activity light on ? does it help you in any way while you are like playing games or something? couse i dont want to keep it on and i dont know if i should unplug it or leave it.
It serves no purpose but to tell you your HDD is active.  Most cases these days don't even have the LED anymore.
https://linustechtips.com/topic/1164691-hard-drive-lights/#findComment-13371810
https://linustechtips.com/topic/1164691-hard-drive-lights/#findComment-13371820
