Hey everyone I'm getting low cpu and gpu usage.
My build is:
GPU: RX Vega 56 Sapphire Pulse
CPU: Ryzen 5 2600
Motherboard: B450 Aorus M
Ram: RAM Corsair Vengeance LPX 16GB (2x8GB) DDR4-3000MHz CL16
PSU: Seasonic Focus Plus Gold 550W Full Modular
I think the ram is also not doing good, since its only at 500 Mhz
One thing I noticed is that if I alt-tab and there is a smaller window in front, i can see the fps in the back go up to 110fps for example, immediately... its like the game is putting down my fps for no reason
This game is Black Desert Online, and its on low settings so I should have more fps...
Thanks in advance guys :D
https://linustechtips.com/topic/1164215-low-cpugpu-usage/
Try check if Low-Power mode is enabled in Graphic settings.
-VBw74WzsVocKsF7r1G-nyHU5dW3B17r9pzWYuzF
Also disable any sort of frame optimizer/cap. Tweak it, don't simply use the low setting slider.
https://linustechtips.com/topic/1164215-low-cpugpu-usage/#findComment-13367648
Just now, ItsNypz said:
My settings are different than mine O.o
Oh, maybe it look different after Remastered edition. ?
Can take screenshot of the graphic settings?
https://linustechtips.com/topic/1164215-low-cpugpu-usage/#findComment-13367654
        This ?
https://linustechtips.com/topic/1164215-low-cpugpu-usage/#findComment-13367660
Interesting, what happen if you use Remastered Mode preset? Does the FPS stay the same?
https://linustechtips.com/topic/1164215-low-cpugpu-usage/#findComment-13367669
2x
Can you check your CPU clockspeed? Or enable it in MSI OSD.
Also can share GPU-Z screenshot? Does it show 500mhz as well?
Radeon Chill enabled? Enhanced-Vsync enabled? Relive enabled?
https://linustechtips.com/topic/1164215-low-cpugpu-usage/#findComment-13367688
Try reboot your PC.
If memory still stuck at 500mhz try DDU and reinstall your graphic driver.
https://linustechtips.com/topic/1164215-low-cpugpu-usage/#findComment-13367704
1 minute ago, ItsNypz said:
whats ddu?
It's a software that nuke your graphic driver. https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
https://linustechtips.com/topic/1164215-low-cpugpu-usage/#findComment-13367711
