Posted March 9, 2020 https://fr.aliexpress.com/item/32862509830.html?spm=a2g0o.productlist.0.0.3b5a7b448kAAEp&algo_pvid=b4790b3f-e83e-4413-874f-293b3b063525&algo_expid=b4790b3f-e83e-4413-874f-293b3b063525-0&btsid=0ab6f83915837901418015071e5a8c&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_ Link to comment https://linustechtips.com/topic/1163419-can-u-help-me-plz/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 9, 2020 Can't think of a PSU that would struggle with a GTX 750 ti Just hope it's not a fake, but I have to say, $60 is pretty expensive for that GPU. You can afford an RX 560 for that price, a ton more powerful. I WILL find your ITX build thread, and I WILL recommend the SIlverstone Sugo SG13B Primary PC: i7 8086k - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 11 and Fedora Linux - Black and green theme, Razer brainwashed me. Draws 400 watts under max load, for reference. PSU tier list How many watts do I need? PSU misconceptions, protections explained, group reg is bad Link to comment https://linustechtips.com/topic/1163419-can-u-help-me-plz/#findComment-13360586 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
