So I am planning to get this system:
 and it has a lot of RGB. I have checked if everything supports MSI Mystic Light and they do but I'm still confused as to how it's all gonna work. The motherboard only has 1 rgb header so how will my case fans and cpu cooler work with 1 header? Or do I have to buy some sort of splitter?
https://linustechtips.com/topic/1160785-rgb-help/
RGB is the least of your problems with this.
Your storage reveals you most likely have no use for pcie4.0, therefore no use for x570, and even if demanding x570 then steer clear of low end msi x570 boards (view this entirely: https://youtu.be/UZWUOldsxXQ ).
https://linustechtips.com/topic/1160785-rgb-help/#findComment-13337854
I went for x570 mainly for 3rd Gen Ryzen support + I asked about RGB not the actual parts. I went with x570 for future proofing reasons.
https://linustechtips.com/topic/1160785-rgb-help/#findComment-13337862
Then i especialy encourage you to watch the vid i linked as THAT is the main reason these boards are discouraged (which has been admitted by MSI themselves, and was reason the boards were discounted and why they came up with the unify).
But hey, give priority to your RGB...
https://linustechtips.com/topic/1160785-rgb-help/#findComment-13337887
The motherboard have
2x 4-pin RGB LED connectors, 2x 3-pin RAINBOW LED connectors
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1160785-rgb-help/#findComment-13337895
Then what motherboard should I get? My friend recommended this one: https://uk.pcpartpicker.com/product/t797YJ/msi-b450-gaming-pro-carbon-ac-atx-am4-motherboard-b450-gaming-pro-carbon-ac
https://linustechtips.com/topic/1160785-rgb-help/#findComment-13338030
1 hour ago, HealthyMindFrsh said:
Thats one of the better b450s in general if i recall correctly, but not sure if it has bios flashback should you not already have a amd cpu.
Other options would be msi's "max" line, (mortar or tomahawk) which are 3000 ready and regarded as some of the best value with decent vrm (opoosite to their x570 boards their b450s where really good).
If wanting to go x570 the asus TUF and Gigabyte aurus Elite are good value.
Note that i dont knowmabout the rgb header specifics of these boards, so thats something to look out for.
Getting back to the RGB, i think the AMD cpu cooler has a usb connector that will go to a internal header on the mobo for controlling rgb but also has rgb header (so, use one, not both) not 100% sure there so doublecheck. The MB520 rgb (manual: https://coolermaster.egnyte.com/dl/v4sJbfV75n/ , download for hi-res, page two, last image) has its own seperate controller that can be connected to a physical switch (can use reset for it) to control the fans.
Final note: apologies if i was a little strong earlier and neglected the rgb question but would feel bad if you found out later about that specific board (esp if wanting to upgrade cpu later) and have buyers remorse.
https://linustechtips.com/topic/1160785-rgb-help/#findComment-13338343
If wanting to go x570 the asus TUF and Gigabyte aorus Elite are good value.
Thanks a lot and from what I know that b450 board does have the ability to update the BIOS without a cpu and apparently it has a 5v and 12v connector for RGB so will that do the job?
https://linustechtips.com/topic/1160785-rgb-help/#findComment-13338364
Its best to post a dedicated seperate question on it (with a updated partslist); there might be nuances im not overseeing for your specific case (thanksfully, all forum members combined have a ton of knowledge and experience).
Personally (might be regional since im in EU) the pro carbon is to expensive here and id lean towards either the tomahawk max for less pricy, or otherwise the x570 elite for a bit more pricy.
Do note that the pro carbon has a "classic" ui once updated for 3000 cpus if i recall correctly (something about the bios chips not being big enough to hold all the new stuff); maybe you dont care but if you do its something to consider.
You are not alone in this btw, ive been doubting and holding off for almost a year now, being in the same boat that none of the options really tick all the boxes i want either quality, feature or price-wise.
https://linustechtips.com/topic/1160785-rgb-help/#findComment-13338397
