There's an Asus Zephyrus S GX531 on sale where i'm located, it's at $2100 down from $2400. There's also the Acer Predator Triton 500 at $2100 as well however it's not on sale. Also there's an HP Omen but at $1900, ~$200 less than the other two. Lenovo Y740 at $1850.
All of these are the same spec.
i7 9750H.
RTX 2070 Max Q.
16GB Ram.
512GB storage however both the Acer and Lenovo has 1TB.
Oh and the Asus apparently has a 240Hz screen compared to 144Hz on the other two.
What do?
Oh and also, it the laptop doesn't need to be crazy thin as i don't really care about it being thin and light. I want a laptop that doesn't sound like a jet engine while also not being too too hot. I know i can't have both but some laptops are probably better than others.
Please suggest other options as well if you can but keep in mind i'm not in the US (Norway) so $2200 probably won't get me as far as it would in the US.
I probably could've formulated this post a bit better but this is what i've got. Thanks in advance for any help/suggestions!
https://linustechtips.com/topic/1160476-need-help-deciding/
