I've bought Fractal Design Celsius S36, it was cheap but broken - but so cheap that it was cheaper than aliexpress 360mm radiator :D Nice thing is that it has a standard G 1/4" connectors, so with broken pump I've thought that I can get rid of pump impeller, get some fittings, hoses, cheap pump with reservoir and get this thing running - or maybe without touching block assembly, just connect another pump, leave stock alone and go. But... will it work? For starters I'll of course try to repair broken one, not sure how at this moment but I'll figure something out. If anything else fails I'll have at least cheap radiator, but I want to run it as cheap as possible.
EVGA X299 Micro, i7-7820X, 16GB GoodRAM IRDM X, PNY RTX 2070 Super, 1x Adata S70 Blade 512GB, 1x MX500 1TB, 1x BX200 480GB, Thermaltake Smart SE 630W, Phanteks Enthoo Pro
https://linustechtips.com/topic/1159867-aio-with-external-pump/
Wait, so you bought it broken for parts?
And I've thought about doing the same thing with mine, but mine works so I haven't actually done it.  Just remember that only the fittings at the radiator are actually fittings.  At the pump those "fittings" are cosmetic.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1159867-aio-with-external-pump/#findComment-13330769
Yep. Cheaper than cheap aliexpress radiator, so I think that I hadn't overpaid.
I'm just wondering if it'll possible to reuse standard pump/block combo as water block alone with another, external pump like chinese SC600 with 5,25" res(good discount atm) or Magicool DCP450.
https://linustechtips.com/topic/1159867-aio-with-external-pump/#findComment-13330984
