Hello,
I am trying to figure out how I can pick the right CPU Fan cooler for my future build. I'm going to use an Aorus Xtreme x570 and a Ryzen 3950x. The current problem I'm facing is I need to find the right cooler. I have little to no idea how to do so. I've heard you need to find out how much TDP the cpu has and find the right fan that goes up to that blah blah, I really don't know. The fan I'm looking to use is a Cooler Master Master MA620M ARGB.
If someone could please tell me if this is a good one to use, if it's compatible, or if I'm over exaggerating cpu coolers as they seem to be quite compatible with most mother boards, I'll be most grateful.
https://www.techinn.com/en/cooler-master-master-ma620m-argb/137476715/p?utm_source=google_products&utm_medium=merchant&id_producte=10349665&country=nz&gclid=CjwKCAiA7t3yBRADEiwA4GFlIy9sqi6o2QA07fraKD30jZ8NzyrPkTa5Lv7DoqLN-B7_heTjNMPPtxoCWWYQAvD_BwE
Thanks!
https://linustechtips.com/topic/1159721-cpu-fan-cooler/
@Trexa, your posts have been merged. Please use Edit to add more content in your posts.
@ApexTheRex
Your case and RAM will be most important parts when choosing the cooler. Don't look at TDP so much, thats manufacturers estimate and there's no universtal standard on how those are measured. Best way to find cooler is to look at your budget, look how your case and RAM will limit the selection and then search for reviews of those coolers left.
You can also use the performance comparison here:
Coolers on the list are purely per performance. So bigger cooler with better fans will be placed higher regardless of their other features or price.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1159721-cpu-fan-cooler/#findComment-13330459
8 hours ago, Trexa said:
a be quiet! dark rock 4 pro would easily handle your cpu
you could also use an aio like a Kraken X73
but yes, yours would also fit ^^
Thanks for your reply! I would use a Dark rock Pro 4 but I just really like the look of these coolers.
https://linustechtips.com/topic/1159721-cpu-fan-cooler/#findComment-13330949
@ApexTheRex
Thanks for your response!
So are you saying that it's all up to my willingness to pay? If so, I don't mind, I'm just looking to know what makes a CPU Fan Air Cooler compatible with a cpu. Are you also saying that if it fits it sits? IF so, then I think I'm good.
https://linustechtips.com/topic/1159721-cpu-fan-cooler/#findComment-13330956
You are looking for AM4 compatibility. That means all major brands and pretty much every cooler still manufactured. If you were looking at TR4, the socket would be a thing to look at. But in reality, you case (how tall cooler can be) and RAM (does cooler overhang RAM slots) are main factors. If you would be using smaller mobo, also blocking 1st PCIe slot. But thats not thing here.
For example. Dark Rock Pro 4, top end air cooler. 163mm tall and will overhang first RAM slot. So you want to have case with room for it (Fractal Design Define R series for example) and RAM without fancy heatsinks (Ciorsair LPX etc.). Or Scythe Fuma 2. Cheaper, but actually not so much behind in pure performance. Much smaller, with 155mm tall and doesn't block RAM slots. Price difference between these two is just under $30USD on Amazon.
https://linustechtips.com/topic/1159721-cpu-fan-cooler/#findComment-13331018
Okay so what I'm looking for is just a Red'n'black RGB CPU fan air cooler. I know about overhang and blocking off different parts of the motherboard and components. But what is the main thing / filter of compatibility to look for when choosing a CPU Air Fan cooler.
Could you find me one? It would also be much appreciated.
https://linustechtips.com/topic/1159721-cpu-fan-cooler/#findComment-13331692
22 minutes ago, ApexTheRex said:
So you just look for the AM4 Compatibility Factor and The dimensions to then see if overhangs any parts. Okay.
I'll check if there are more later, but from the top, CoolerMasters MA620M/MA410M fit your needs. If you wouldn't overclock, then even 212 RGB could do.
https://linustechtips.com/topic/1159721-cpu-fan-cooler/#findComment-13331745
Ah great, thanks very much. Yeah I'll be trying to overclock with it. All I need to know is what makes a CPU Air Fan Cooler Compatible with the motherboard and cpu. That's all I want to know.
https://linustechtips.com/topic/1159721-cpu-fan-cooler/#findComment-13333945
The supported CPU sockets are listed in coolers specs. The cooler needs to have suitable mounting hardware as sockets are different sizes and shapes.
https://linustechtips.com/topic/1159721-cpu-fan-cooler/#findComment-13334296
Well, in that case that cooler doesn't show the socket listed.
https://linustechtips.com/topic/1159721-cpu-fan-cooler/#findComment-13343016
Or rather store page doesn't have it listed. Here's UK store with sockets listed https://www.scan.co.uk/products/cooler-master-masterair-ma620m-cpu-tower-cooler-6-heatpipes-dual-heatsink-arbg-120mm-2000rpm-pwm-fan
Besides coolers own product pages on manufacturers site, Pcpartpicker.com is also great resource.
https://linustechtips.com/topic/1159721-cpu-fan-cooler/#findComment-13343090
Check out the cooler website: https://www.coolermaster.com/catalog/coolers/cpu-air-coolers/masterair-ma620m/#Specifications
What kind of look are you aiming for? The MA620M doesn't seem very good.
What case and ram are you using?
https://linustechtips.com/topic/1159721-cpu-fan-cooler/#findComment-13345252
