latency problem need help plzzzz
Solved by Guest,
38 minutes ago, Mythical2 said:what else could i do
Thinking on it. At work too. Sry for slow response times....
Gotta find out why you get hard faults.
Edit.
Was thinking about page file usage and size but you are not maxing the system memory so the page file is not likely being used.
May have to warranty the drive.....
