It is possible and sometimes very profitable, what country are you in? Makes it easier to recommend parts then
I live in the land down under and not afraid of a kangaroo
 Gold rainbow six player going to yeet on ur bitch
Intel pentium g4560
msi z170m mortor
12gb ddr4 2400mhz (oc to 2666mhz)
1tb hard drive
gtx 750 ti
some game max psu 500w 80+
https://linustechtips.com/topic/1159268-my-first-self-built-pc/#findComment-13325541
16 minutes ago, Yuval12l said:
Israel.
Any budget, and can u convert to aus
Intel pentium g4560
msi z170m mortor
1tb hard drive
gtx 750 ti
https://linustechtips.com/topic/1159268-my-first-self-built-pc/#findComment-13325583
I just saw the budget
Intel pentium g4560
msi z170m mortor
1tb hard drive
gtx 750 ti
https://linustechtips.com/topic/1159268-my-first-self-built-pc/#findComment-13325585
Is that isrealian $$$?
Intel pentium g4560
msi z170m mortor
1tb hard drive
gtx 750 ti
https://linustechtips.com/topic/1159268-my-first-self-built-pc/#findComment-13325586
Just now, Yuval12l said:
sure. let's say about 600 usd.
Ok sweet , so a rough picture if u can find it on fb market place etc, rx 570 or 1060, a 4th gen or 6th gen i5 or 2nd gen ryzen, if u go for 4th gen i5 u will need ddr3 ram try to get 16gb but if u go for 6th gen any ddr4 and for ryzen fast ram at least over 3000mhz qnd a 600watt 80+ bronze or gold if you can
Intel pentium g4560
msi z170m mortor
1tb hard drive
gtx 750 ti
https://linustechtips.com/topic/1159268-my-first-self-built-pc/#findComment-13325594
I can purchase an msi gtx 980 ti for 100 usd. I know it's pretty old but still can run most games I guess. or should I focus on the ones you recommended?
https://linustechtips.com/topic/1159268-my-first-self-built-pc/#findComment-13325608
The 980 is really good but it uses alot of power so might want a 700watt and make sure the psu comes with the power connectors the 980 needs
Intel pentium g4560
msi z170m mortor
1tb hard drive
gtx 750 ti
https://linustechtips.com/topic/1159268-my-first-self-built-pc/#findComment-13325610
CPU (new): AMD Ryzen 5 2600 $138
MOBO (new): MSI B450 Tomahawk Max $115
RAM (new): 16GB Patriot Viper Steel DDR4-3000 $68
GPU (used): Nvidia GTX 1060 $85
PSU (new): Corsair RMx 550W 80+ Gold $90
Case (new): Deepcool Matrexx 70-ADD-RGB $92
= $588 USD total (plus shipping if applicable)
Pretty decent for 1080p gaming, however I would recommend upgrading and or starting a new build annually every 3 to 5 years afterwards to keep up to date with the latest hardware.
https://linustechtips.com/topic/1159268-my-first-self-built-pc/#findComment-13325636
= $588 USD total
Very good but i would go for the 980 ti, for 100$ that a steal
Intel pentium g4560
msi z170m mortor
1tb hard drive
gtx 750 ti
https://linustechtips.com/topic/1159268-my-first-self-built-pc/#findComment-13325640
50 minutes ago, Yuval12l said:
Israel.
Wish I knew more about the Israeli PC market. Is Amazon pretty accessible? What about Newegg?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1159268-my-first-self-built-pc/#findComment-13325646
Intel pentium g4560
msi z170m mortor
1tb hard drive
gtx 750 ti
https://linustechtips.com/topic/1159268-my-first-self-built-pc/#findComment-13325653
All very accessible.
In which case, you could probably afford a rig very similar to this
3 minutes ago, Yuval12l said:
The power supply is not great, how much would a Corsair cx450 cost you? Also the motherboard could be better in terms of power delivery, is the Asrock b450 Pro4 an option?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1159268-my-first-self-built-pc/#findComment-13325657
It is possible for the price of 625 usd. is 450 psu enough?
https://linustechtips.com/topic/1159268-my-first-self-built-pc/#findComment-13325670
459 watts is plenty, quality matters a lot. If you want that 980 ti, you should get the cx450m or cx550 because those will have enough connectors. Also look at the be quiet pure power 10 and 11, or system power 9, or also the cooler master MWE V2 (bronze or white). You could also consider the bronze V1 for 650 watts or higher, but I doubt that would be very cheap.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1159268-my-first-self-built-pc/#findComment-13325674
Actually I'm waiting for an answer from the guy who sells the 980 ti. disregarding price difference, what would be better the 980 ti or the rx 570 8gb?
The 980 ti performs pretty close to the GTX 1070, and that's way ahead of the 570. They're often about $150 compared to the used rate of the 570's $75 or so.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1159268-my-first-self-built-pc/#findComment-13325682
8 hours ago, Yuval12l said:
Hi, is a new sapphire rx 570 8gb worth 145 usd?
Is it a blower style cooler?
Intel pentium g4560
msi z170m mortor
1tb hard drive
gtx 750 ti
https://linustechtips.com/topic/1159268-my-first-self-built-pc/#findComment-13331446
